With the kind permission of Organizing Committee of
the 5th International Conference ArtCast 2010.
63 Titles & Authors:
New Developments in High Quality Grey Cast Irons - a Review Iulian Riposan, President of
Romanian Foundry Technical Association
Section I
- Applications of Non-invasive Techniques in the Analysis of Corrosion Crusts Formed on Archaeological Metal Objects
Ion Sandu, O. Mircea, I. Sarghie, Andrei-Victor Sandu,
C. Marian, Viorica Vasilache
- Scrap Quality and Metallurgical Effects Associated with Copper and Tin as Tramp Elements in the Casting Steels
Anisoara Ciocan, Florentina Potecasu
- Art Casting: Foundries in Internet and Some Applications
Olivier Duhamel, Denyo Alipiev
- Decorative Surfaces Obtained Through Thermal Zincking
Tamara Radu, Florentina Potecasu
- The Exploitation of the Copper Sheet Wastage in Applied Art
Gheorghe Florea, Daniela Buruiana (Negoita), Alexandru Chiriac, Adrian Vasiliu
- Artifacts in the Getae-Dacian Treasures
Ana Doniga
- Alloys Used at Decorative Parts Inside the Airplanes
Stefan Dragomir, Alexandru Chiriac
- History of Faberge Eggs
Gheorghe Croitoru, Ion Rusu
- Time Analysis of King Matthias the 1st Sculptural Group
Julieta Daniela Sabau (Chelaru), Vasile Filip Soporan, Ovidiu Nemes
- Value Analysis Between Art and Technique - Part I
Florin Chichernea, Alexandru Chichernea
- Value Analysis Between Art and Technique - Part II
- Making Art Replica Models Using 3D Scan and Electrodepositing
Aurelia Stanescu, Alexandru Stanescu, Bogdan Florea
- Materials Used for Manufacturing Some Objects From 1600 Before Christ - 500 After Christ Period
Petrica Hagioglu, Constantin Gheorghies
- Art Works Casting Using Wax Patterns
Beatrice Tudor, Marian Bordei
- The Main Data About the "Big Bell" of the Black Church in Brasov
Viorel Ene, Tibor Bedo, Marius Benta
- 27 March 2009 - 150 Years from the Blessing of the "Big Bell" of Black Church in Brasov
- Sculpture, Extended Nature
Elena Paraschiv, Victor Paunescu, Cristina Raducan
- The Process Involved in Making the Medals
Daniela Buruiana (Negoita), Gheorghe Florea, Alexandru Chiriac
- Use of Unconventional Materials to Obtain Pieces of Urban Art
Stefan Dragomir, Gheorghe Florea
- Sanitary Silicone Used to Make Small Art Cast Parts
Tibor Bedo, Viorel Ene, Ioan Ciobanu
- Do Birds Represent a Menace to Outdoor Monuments?
Adrian Vasiliu, Daniela Buruiana (Negoita)
- Artifacts Protection Coatings
Ana Doniga, Miltiade Istrate
- Obtaining and Characterization of Vitroceram by Chemical Doped ZnO for Art Mosaic
Ion Sandu, C. Bejinariu, Andrei-Victor Sandu, Viorica Vasilache, I.G. Sandu, M. Branzila
- Vacuum Casting of Objects Made of Precious Materials
Beatrice Tudor, Daniela Buruiana
- New Achievements in Manufacturing of Church Bells
Gheorghe Florea, C. Oancea, C. Gheorghies
- Studies Regarding the Achievement of Light Fuse Models for Casting the Art Objects
Bogdan Florea, Cezar Balescu, Vasile Mirea, Augustin Semenescu
- Weapons as Work of Art
Ana Doniga
Section II
- Investgation of Titanium Hydride Produced from Titanium Waste
Yavor Lukarski, Jordan Georgiev, Lubomir Anestiev, Rositsa Gavrilova, Simona Bejan
- Research on Abrasive Wear Behavior of Laser Cladding Layers with High-speed Steel Powder Type HS6-5-2-M2
Simona Boiciuc, Elena Drugescu
- Study on the Material Flow at the ECAE Process
Nicolae Cananau, Gheorghe Gurau, Carmela Gurau
- Research on the Complex Microalloyed Zinc Melts
Tamara Radu, Lucica Balint, Maria Vlad
- Contributions to the Study of Some Special Materials from the Al-Mn-Fe System
Alexandru Chiriac, Maria Vlad, Stefan Dragomir, Gheorghe Florea
- Physico-mechanical and Physico-chemical Properties of Bio-inert Composite Ceramics
Anna Petrova, Silvia Simeonova, Radoslav Valov, Vladimir Petkov
- Some Considerations on Environmental Sand Cores with Inorganic Binder
Tibor bedo, Viorel Ene, Ioan Ciobanu
- The Kinetics and Thermodynamic Transformation of a Special S.G. Cast Iron
Ioan Milosan
- Some Key Elements for Improving the Total Quality Management Concept
Ioan Milosan
- Influence of Inclinations Applied to Ribs on the Solidification of Cast Parts
Aurel Crisan, Diana Tutuianu, Tibor Bedo, Ioan Ciobanu
- Influence of Corner Radii Applied to the Joining Area of the Rib to the Part Wall on the Solidification of Cast Parts
- Composite Coating in Copper Matrix with Molybdenum in Dispersion Phase Obtained by Electrochemical Methods
Olga Mitoseriu, Florentina Potecasu, Stela Constantinescu, Lucica Orac
- Problems and Solutions Regarding the Centrifugal Casting of Wire Sheave for Heavy Cranes
Nicolae Cananau, D. Scarlat, Gheorghe Florea
- The Ecological Impact of Metallurgical Industry
Carmen-Penelopi Papadatu
- A Setup for Preparation of Glass-carbon Coatings on TiO2-Nb2O5 Intended for Hip Joint Prostheses
Jordan Georgiev, Stefan Stefanov, Dimitar Teodosiev, Lubomir Anestiev
- The Influence of the Heat Trearment upon the Resistance to Corrosion of the Composite Obtained Using the Electrodepositing of TiO2 in a Nickel Matrix
Raul Novac, Olga Mitoseriu
- Permanent Forms for Casting More Sustainable, Cladding Hard Alloys
Ovidiu Dima
- Electro-corrosion Behavior of 7075 Aluminum Alloy After Ageing Treatment
Roxana Stefanica, Carmen Nejneru, Vasile Manole, Ramona Cimpoesu Hanu
- Researches Regarding the Obtaining of Some Composite Materials with Metallic Matrix Obtained Through Casting
Vasile Basliu
- Materials for Total Hip Joint Prostheses: Biaxial Flexural Strength of Two Ceramic Systems
Bojana Tabakova, Ivanka Kalimanova, Ina Yankova, Hristiana Nikolova
- Thin Layers Obtaining by Electric Spark in Liquid Medium
Ion Hopulele, Carmen Nejneru, Manuela Cristina Perju, Mihai Axinte
- Corrosion Resistance in Neutral Saline Fog of the Composites Cu-Mo Obtained by PVD Method.
V.G. Grechanyuc, N.I. Grechanyuc, Lucica Orac
- Soil Pollution with Heavy Metals
Maria Vlad, Gelu Movileanu
- Consideration Regarding the Heat Treatment of Sheets and Strips from Aluminum Alloy 5052 Type
Alexandru Stancioiu, Olga Mitoseriu, Marian Bordei
- Theoretical Study Regarding the Flow Conditions for Alloys Through Thin Channels
Ioan Marginean, Bogdan-Alexandru Verdes, Sorin-Adrian Cocolas
- Quality Assurance of Cylyndrical Casted Parts with Small Thickness
Nicolae Cananau, Alexandru Chiriac, Vasile Bratu
- Research on the Effect of Temperature and Duration of Immersion on the Layer Thickness of Zinc Coating Obtained in Microalloyed Zinc Melts
Viorel Dragan
- Characterisation of Niobium Carbide Chemical Deposition from Vapour at Normal Pressure
- Glass-carbon Bioactive Coatings on a TiO2-Nb2O5 Substrate
Dimitar Teodosiev, Lubomir Anestiev, Jordan Georgiev, Nartzislav Petrov, Petar Tzvetkov, Cristiana Nikolova
- Sources of Emissions in the Sintering and Blast Furnace Plant
Alexandru Chiriac, Gheorghe Florea, Ioan Saracin, Olimpia Panda
- Influence of Rib Lenght on the Solidification of Cast Parts
Ioan Ciobanu, Diana Tutuianu, Tibor Bedo, Aurel Crisan
- Influence of Rib Thickness on the Solidification of Cast Parts
- Electrodeposition and Characterization of Zinc-Cobalt Alloy Coatings
Violeta Vasilache, Sonia Gutt, Ion Sandu, Gheorghe Gutt, Traian Vasilache
- Development of a New Installation of Elaboration-casting in order to Obtain Composite Materials with Metallic Matrix
Vasile Basliu
- Structural Aspects of Antifriction Properties Brass
Alexandru Chiriac, Gheorghe Florea, Marian Neacsu, Ioan Saracin, Olimpia Panda
- The Behavior of Some Non-conventional Treated Steels During Wear Process (III)
Some pictures from the Conference ArtCast 2010 » » »
